:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Wed Dec 21, 2005 5:19 am
To remove and replace the head, even without valve work, will be 8-10hrs labor...so if the shop charges 60-80 per hour...that's in the ballpark.
You can buy a running KA for less, and swap it i in ~6hrs or so...easy stuff.
I'd go that route, or fix the current motor yourself. It's already screwed up, so why not try to fix it, learn as you go...you'll be better off in the end having tried and learned...even if you wind up putting a new KA in later if you can't fix it.
Remember, it's only nuts and bolts...and with an FSM, you can fix anything.
- Brian
