Nismo_Freak »
https://forums.nicoclub.com/nismo-freak-u248.html
Wed Jul 23, 2003 6:42 am
ECU is located in the right side passanger's kick panel.
Pull it out (2 or 3 bolts (10mm) IIRC).
Find the screw on the ECU (flat head screw), should be on the side.
Turn ignition to ON position
Now, turn the screw clockwise until it stops (DO NOT FORCE IT!), it should be circa ~ 1.5 rotations.
Count to 5
Turn screw back to original position.
The MIL (Check Engine Light) should be flashing.
Here's how you read the code. - Count the number of LONG flashes - Count the number of following SHORT flashes- MIL will pause, it will then repeat the 1st code or give you another diagnostic code.
The LONG flashes give you the first two digitsThe SHORT flashes give you the second two digits
1 Long and 3 short would equate to a P0103 error code3 Long and 4 short would equate to a P0304 error code
Post what comes up and we will be able to tell you exactly whats going on with the MIL.
