harryg wrote:also remember that the ECU "learns" your driving habits and therefore performs in that way...
I have not been able to determine if the CVT computer has any 'self learning' capability. The manual does not show any or how to reset it if required.
I think the other comments are valid. ie. The CVT tries to obtain the best fuel efficiency under most conditions by running the highest 'gear' it can. Sometimes it feels sluggish as a result For a roughly 3400lb vehicle equipped with a high torque (at low rpm) 2.5L 4cyl, the Rogue does well. It's surely not a V-6 or V-8, but it doesn't consume gas like one either.
My suggestions? Try the following for those really steep hills:
If you have the paddle shift option: Select a lower gear for climbing hills.If you don't: Use the overdrive lock or low gear.
Finally,
The engine will not produce the best power or fuel efficiency until fully broken in. This can take up to 4000mi (6,400km). Give time for your vehicle to break in... you will surely notice a difference.
