Is this possible?
prigo
bad power steering pump causing sporradic idle, and sometimes idle to drop low enough for the car to die?
S14Life
Car: b5 s4 stage 3, 2001 pathfinder, 91 s10
Unless the steering pump seized, I don't see how it could affect your idle..
And your idle would have to be pretty damn low to stall. What's your idle set to right now?
prigo
pre the problem, it was 650ish at idle, 900 or so with the AC on.
my power steering is gone, thats why I asked.
tonynalli
you can adjust the idle by turning the idle set screw on the side of the air plenum.
PROJECTRB240SX
Car: 1972 DATSUN 240Z W/ SR20DET
IF THE IDLE DROPS BELOW 500RPM THE CAR DIES.... A POWERSTEERING PUMP WITH A LOCKED UP PULLEY WOULD BREAK THE BELT........ IDLE IS EFFECTED BY VACUUM, IDLE CONTROL, TIMING, AIR LEAKS, LEAKY GASKETS, AND AIR/FUEL MIXTURE.
tonynalli
actually it might not break the belt, there is a possibibltiy that it will stretch. it might not be locked up but on the way.
Hellion240sx
Car: 1992 240sx se
you think exhaust leak too, project????
prigo
Yea, but I've had a vaccum hose go out, and it effected my brakes last time :(
prigo
Also, when the idle starts to wig out, i hear noise from either the power steering pump, or the air conditioner (that area).
PROJECTRB240SX
EXHUAST ISN'T TO DETRIMENTAL TO IDLE BUT IT COULD BE A CAUSE.
THE REASON YOUR BRAKES GOT HARD WAS BECAUSE THE LOSS OF VACUUM TO THE BOOSTER PUMP.
THOSE ACCESSORIES COULD HAVE A HAND IN THE CAUSE... JUST CHECK TO MAKE SUR ETHE PULLEYS ARE FREE SPINNING.
prigo
fo sho, thanks for the help, ill post again later if i figure it out :D
prigo
Took a closer look earlier, and when the idle is screwed up, the air conditioner appears to not be spinning freely. Looks like it could be the problem :(
ricebike
2002 Quest
2005 Altima
i dunno, when my ps pump decided to die out n spit fluid allover the ground, the engine idled funny & stalled... i restarted it n limped it home for 3 miles...
prigo
Yea, evidently my power steering pump bearing is dying or somethin'. Theres metal flakes all over, meaning something was scraping. (This is the conclusion my neighbor came too.)
Hellion240sx
Car: 1992 240sx se
yeah i was low on ps fluid and it was making some hoorrid noises, til i put some fluid in there :) now its all better!
