Is this possible??
Omni
http://www.skylinesaustralia.com/forums ... tion-help/
i saw it whiile i was on the australian forum and was wondering since i am using my friend regular s2 engine harness would that problem happem to me??
i know that the cas he was using was the metal one and since i have the plastic one do i have to really rewire the the cas wiring like it says in the post??
I did not want to touch anything without fist hearing what u guys think
mixeds14
Car: 240
:tisk: man, i believe ur questions were answered on your past post before.... u should of save a bit more cash n have a pro done ur harness instead of buying another one...
Omni
i didnt buy one a friend lent me his to test and if it worked i can keep it so if you are not gonna comment on what i posted and insist on me spending money you are not really helping..SIMPLE answer to what i asked yes or no plain and simple nothing more or if someone wanted to go into more details fine...but unless u givig me the damn nar 550 for a harness stop mentioning it
mixeds14
Car: 240
Omni wrote:i didnt buy one a friend lent me his to test and if it worked i can keep it so if you are not gonna comment on what i posted and insist on me spending money you are not really helping..SIMPLE answer to what i asked yes or no plain and simple nothing more or if someone wanted to go into more details fine...but unless u givig me the damn nar 550 for a harness stop mentioning it
this is from ur other post..
Well guys i bought a harness and i am not seeing the blue relay on it...is it possible to delete it or something cause even though i have one sitting around i wanna know whats up cause i am not seeing it nowhere on the harness need some advice please...also my starter is getting 3 volts like i dunno wth is going on smh...
on the cas YES..is wire diferent search on ur past post and u will see that i n other answer that question before n even told u how it was wire..
but ok, i wont mention that anymore n i will stay out of ur post
Omni
ok thats the one i bought from the prick on ebay and now a friend lent me his to get my car running but the different is he had the mitsu cas and i have the black one thats why i am asking and i am positive i posted that in that same post that a friend is gonna let me try his
and this is what i posted "ok will do..and uhm i think my cas is bad so i plug my friends harness up and seems good so far...engine cranks over and nothing so so i think its my timing is off...so i take out the cas set the timing back to TDC and a though came to mind i should spin the cas to hear is my injectors click and i get nothing..absolutely nothing...but when i plug the cas plug..the fuel pump goes off and i hear a click at the end...but when spinning the cas by hand manually no injectors clicking..could it be the wheels thats messed up and if there a replacement i cant get instead of buying a whole new cas??"
the forum is for help and instead of reading apart of the thread that you wanted to read to make a point..read the whole thing..i am someone who can generally figure stuff out on my own so if i ask for help that means i really need the help and not someone pestering me to buy something like money grows on tree's yes it would be all nice and dandy to own one of those sickly made harness but not in the position for that..and i know bost cas are differnet but i am asking about the wiring..as once again you didnt read the link i posted cause u would have seen what i was asking about
StricNyne
okokok the issue is a mechanical one not just a wiring one, your have a CAS that is specific to your cams (dimple) ALL other CAS use the half moon. even if u swap cas from any other motor it will not go on the cam. you can try and rig one by making a hybrid, but idk if it will work. YOU NEED THE BLACK PLASTIC CAS, nothhing else will work unless u change cam
Omni
no stric you are not getting what i am asking here...look at what the post on the auttralian forum says it showe the different between the regular cas wiring and the neo cas..i was asking if sine my friend has the regular cas on his car would i need to change the cas wiring around or are they the same that is all i would like to know thats why i put the post in here.. ok i got my answer forget it
StricNyne
... the splines on the CAS are differant, its a mehcanical issue no wiring is going to fix this issue, so if u get his new car, and repin the plug, it STILL will intergrate with the cam
