whiterps13 »
https://forums.nicoclub.com/whiterps13-u9007.html
Fri Mar 24, 2006 4:44 pm
thanks for listening to my other post in 240 general.
in regards to your question, it will throw the handling off very much. having ****ty tires up front will do nothing but promote understeer, a problem a stock 240 already has.
assuming you want to drag race, it will work. thats why you see every fox body running around the drag strip with skinnies up front.
however if you actually want to turn sometimes, id suggest either running the same tires all the way around or putting the all seasons in the back. this takes care of some of the stock understeer, but limits your traction in a sraight line. but if you need to save money, putting them in back would make the most sense in regards to handling. i have experimented with this idea before, and it makes "drifiting" or oversteering on the street much more feasible without going over 60mph. btw i was running yoko parada spec 2's up front with khumo ecsta 711's out back (yes, they suck, but for $50 a pop you cant beat em)
