Is this Oil Cooler / FIlter Relocator Diagram Correct?
sepulchralx
Car: 240sx
Just want to make sure i'm doing this alright.
Nissan2367
I would run the clean oil through the cooler not the dirty oil.
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
dirty oil from the block goes into the oil filter housing to the outside of the filter, then out of the center of the oil filter to the cooler, then from the cooler bk in to block
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Make sure you run a thermostatically controlled oil sandwich adapter (i.e. Greddy).
sepulchralx
Car: 240sx
i just bought one... hit me $120
darius: the company that sold me the harness for $50 threw an an ecu for free as long as i sent the old ecu back
Modified by sepulchralx at 2:15 PM 2/20/2009
Nissan2367
Darius wrote:Make sure you run a thermostatically controlled oil sandwich adapter (i.e. Greddy).
Meaning? Sorry if thats a noob question... Does it have a thremostate like the cooling system to let the oil through only once its hot... Sorry if this is a sstupid question its like 1am!
Darius
Mike - That is a sweet deal! Hopefully that was the issue.
Nissan2367 - Yes, you are correct. The thermostat inside the sandwich filter operates just like the thermostat in the cooling system. It only opens once the oil reaches the trigger temperature. Without it, the oil temps could remain "cold" on cold days and the air-to-oil cooler is an efficient one.
SullivanRacing06
i ran a greddy filter relocation adapter that screwed on to the block, no t stat, i have a oil temp gauge so i keep a eye on it but if u dont let ur car sit n warm up then get the one w the tstat
Neejay
Does the OEM oil cooler on a RB25 suck?
Can you just remove it and install the sandwich adapter?
neonbomb
We have oil coolers from the factory?
Neejay
neonbomb wrote:We have oil coolers from the factory?
If I'm not mistaken? What's this?:
Darius
Yes that is it. Please refer to the FSM or SEARCH for this info. So basic.
sxracerb25
Car: 1990 Nissan 240sx
Neejay wrote:Does the OEM oil cooler on a RB25 suck?
http://shop.rawbrokerage.com/p...d=229
That lets you run without the factory oil cooler. I'm not sure as to if it sucks or not just saw that on raw brokerage.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
Neejay, neonbomb;
I'm resisting the urge...
Yes, that _is_ the factory oil cooler.
Neejay
Darius wrote:Yes that is it. Please refer to the FSM or SEARCH for this info. So basic.
l0nestar wrote:Neejay, neonbomb;
I was 85% sure (person who told me is questionable), until neonbomb made it sound like I was crazy. My question was almost rhetorical.
lol calm down guys.
