elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Thu Jan 05, 2006 4:32 pm
What happens is, even if the climate contorl is turned off, it will still bring air through it.. via air pressure from the car moving... This way fresh air is always being pumped into the car, either with the fan or not!
It keeps your setting in memory and if you have the heater up all the way when you turn it off, thats how it keeps it......
Also a neet little feature thats not mentioned in the FSM or owners manual, you can turn the climate controller off, and then press one of the vent mode buttons (footwell, face, etc) and it will blow air in without the fan being run... I like it when its nice outside and also keeps fresh air coming in... the climate control will light up and you can control it that way too...
