and what have you seen this on ?a J&S is cheap insurance considering the big picture... I have seen it keep engines running insane amounts of boost from blowing sky high, and I've also seen it prevent catastrophic failure when something stupid happens, limiting damage considerably...
that and more, has been their advertisement from way back. Sounds great, but...... if it is such a fantastic piece of equipment, with aforementioned capabilities, why has it not caught on yet.... even what, some 12 years later ?J&S safeguard can react faster than 99% of all road vehicles today... it not only retards timing from knock detection PER cylinder, it also advances timing up till the knock threshold to maximize engine performance
I disagree entirely. I had zero issues while running a TD05-14b with a 6cm^2 hotside and anybody who's run one with those specs knows how quickly that little huffer winds up. Spooled hard from ~0.2 to 1bar in something like 500rpm and my final timing matches the tables exactly in all load conditions. The ECU is not the problem. Did you use the knock copy function to copy your timing map to the knock map? One thing that IS quirky with the CA ECU is it averages the High Octane and Low Octane maps to determine final timing.mr_ca18det wrote:Due to the ca ecu being older than the Sr its slower to respond to what's programmed in the maps. For example when i had my s15 turbo lets say i had my timing at like 30 before spool up and if you try to taper it down to say 16 when in full boost the computer cant adjust fast enough and your timing will drop down to like 8 degrees then when your in the higher load areas it stay in longer it will come back up to where it should. Does that make sense. But i'm not the only one with this problem its not the end of the world and its not a nistune problem its just a slower computer so fast adjustments arent possible. And megasquirt can control everything boost luanch control. I'm almost possitive ca ecu run a 128 bit system as opposed to the sr is 256 maybe. But if your running it stock or light mods nistune works its just fast spooling turbos dont work very well. There is ways to get rid of a lot of the timing drop just takes alot of messing with. But its super easy to use and is user friendly
