Is this normal
300freekzx
Car: 1990 300zx N/A, 1992 Honda Accord LX , 1991 Honda Accord LX, 2006 M35 Sport
When I crank my z up I can hear water flowing behind the dashboard. It sounds like pouring water into a sink from a cup. Then is calms and go away. Is that normal?
CrazedZ32Owner
Car: 91 Z32 TT(no motor), 2008 350Z Nismo, 05 Pontiac Sunfire speed machine!!! :)
hmm could be your heater core has a leak maybe.... which would require you to pull your dash...do you smell coolant when you turn the heat on??
300freekzx
I have no leaks in the car at all so I do not know. I was wondering.
BigTDogg (MA)
Car: 1990 Nissan 300ZX TT
Try burping your coolant system. Start the car from cold, with the radiator cap off, on a slight incline with the nose of the car higher than the tail. Run the heater on full blast 90 degrees and let it idle for a while with the radiator cap off. Once the engine reaches temp and the thermostat opens, you should be able to get any air out of your system.
300freekzx
Thanks bro!
Zwicked
Car: 1990 300 ZX tt, 1990 240SX
300freekzx wrote:When I crank my z up I can hear water flowing behind the dashboard. It sounds like pouring water into a sink from a cup. Then is calms and go away. Is that normal?
Sounds like your system might be low on coolant. That sound is gulps of air going through the heater core
300freekzx
cool I will burp it again today
300freekzx
Update: I burped the car today it had shown improvement but it still goes up. I will burp it again to see if additional air is in the system. I will say stayed are normal temp more than at high temp so something is working.
