is this normal for t25
Emperor_Tha
as of now, after getting some strong driveshaft bolts, cleaning the aiv, throttle plate, and turbo inlet, i am now boosting at 10psi with no boost controller. before i would boost at 7psi.
fmic, full 3inch exhaust, fpr, greedy bov, and autometer boost gauge.
kainvamp
Car: '91 Sil80 w/ SR
None of that you did would change how much boost you run. Maybe check the vacuum line to yuur wastegate actuator for a leak. I suppose if it had a leak the actuator wouldnt see as much boost and the wastgate wouldnt open until it did?
BTW do you have a red s13 hatch?
Emperor_Tha
no, mine is primer grey and its still not ready to be register yet
fc3sdrifter121
opening up the exhaust and intake will normally raise boost alittle
jbracy7
Car: 94 GTS TYPE-M in a dozen pieces
emperor what fmic are you runing
Emperor_Tha
greddy m spec
evil_intent
Did you have the stock boost solenoid before?
