Is this normal for KA's to run this?
Clearalbino
Alright, So I headed over to the track to see what kind of times my car was running, this is what I got
60' 2.345330-6.9411/8-10.733MPH-64.29
1/4-16.778MPH-80.90
Car as follows
1995 S14
Engine-
Injen CAIguttet catalytic2.5 inch magnaflow exhaustplugs, wires, o2 sensor, basic mantaince
Suspension, tires, driveterrainKYB AGX with Eibach Pro-kitFalken ST-115J30 VLSD
naed240sx
Car: .....
Nope. That's terrible. What rpm point were you shifting at?
gizzerd
Car: 1989 240sx Hatchback
Hmm....auto or manual? I ran a 15.9 in my sohc S13, with only a few basic mods and good suspension. I would think you would be running a better time than me for sure, but I've never driven an S14. Hopefully somebody can chime in with a little better info for ya!
Ezzo
Few more determining factors, Did you buy the car used? Did you know the previous owner? or the condition of the KA before you bought it?
Before you started putting aftermarket parts on it, what kind of maintenance did you do on it? have you compression tested it yet? How’s the condition of your clutch? (if your a 5speed)
Aside from mechanical problems, it could just be you. What RPM were you launching/shifting at? Did you get many passes? Was it your first time on that track?
There’s a million reasons you could add or lose a second or two when your taking street cars to the track. Just narrow it all down.
naed240sx
Car: .....
Ezzo wrote:Few more determining factors, Did you buy the car used? Did you know the previous owner? or the condition of the KA before you bought it?
BlackHat
Car: 1989 Nissan 240sx Hatchback
Did you have stickers on your car? That's gotta be at least 2 seconds...
I agree with above, adding stuff can be tempting and REAL easy compared to fine combing your setup. Making sure everything is running great first is always less exciting then adding new stuff.
180fastback
Car: 240 sx
or just slow reaction to the light or just plain and simply the dude cant drive
TheOne
Car: 93 240sx FB
thats quite bad, i ran my S13 with worn tires, about to blowup headgasket and messed up suspension and ran a 10.5 in the 8th mile.(haven't ran quarter yet)
racin-type
Car: cars
I ran a 16.1, forgot what trap speed was. 95 s14, with only suspension and wheel/tire.
probably coulda gotten a 15.9 if i can launch better.
launched around 3k, tried 3 times. 1 bog, 1 spun slightly
Nismo1182
Car: Z06
Thats a bad 60' and a low mph. I'd compression test that motor.
180fastback wrote:or just slow reaction to the light or just plain and simply the dude cant drive
Reaction time does not affect E.T
BIGT94z
Nismo1182 wrote: Reaction time does not affect E.T
finally a smart person...you can get out check ur tire pressure get back it and run the 1/4 rt does not do jack for ur 1/4 time....i ran a 15.6 on my auto 95 240sx with header/intake/2.5 exhaust/ denso plugs/ crappy hancook all season v4's....my slowest run with my 5 speed was a 15.46 with a 0-60 at 2.3
ddgsxr504
Car: 1995 Nissan 240SX SE 2007 Infinit M35 Sport 2011 Nissan Pathfinder Silver Edition
I am thinking a compression check is in order as well.
I have a slew of parts on my S14 so I run 15.0-15.1 but I am pretty sure stock 1/4 mile times for an S14 should be around 15.7 or so.
Modified by ddgsxr504 at 3:08 PM 6/8/2006
SeanC
Car: 1993 240sx SE
my s13 with 3" exhaust ran a 16.1 my first time with street tires. at 84 or 85 mph
BIGT94z
SeanC wrote:my s13 with 3" exhaust ran a 16.1 my first time with street tires. at 84 or 85 mph
my worst run was in the 16's bc my 0=60 blowed but my trap speed was still 88 and some change
BIGT94z
ddgsxr504 wrote:I have a slew of parts on my S14 so I run 15.1-15.2 but I am pretty sure stock 1/4 mile times for an S14 should be around 15.7 or so.
whats all done 2 your s14?
slickster1013
I brought my 93 coupe, 5speed, to the track and ran a 15.9 twice in it, and all i have done is an injen intake a muffler, that's it. On street tires and everything. Guess i'm just a good driver....lol
BIGT94z
ur track time depends on ur 0-60 ft times....i ran a 16.0 with a 2.49 with a 2.39 i ran a 15.42....it all depends on ur launch if u dont have a good one u will have a sucky run....simple as that
ddgsxr504
BIG_T wrote: whats all done 2 your s14?
Port & Polished HeadJWT Cams & Tuned ECUInjen CAIHotshot Header2.5" Test Pipe3" Apexi N1 ExhaustBosch Platinum PlugsAccell 8.5mm WiresFidanza Aluminum FlywheelOEM Exedy ClutchOBX Short ShifterStainless Braided Clutch Line
Just a few off the top of my head.
BIGT94z
how ur like ur accell wires i just ordered some from partandaccesories.com the other day...should be here tuesday
ddgsxr504
BIG_T wrote:how ur like ur accell wires i just ordered some from partandaccesories.com the other day...should be here tuesday
Don't really notice that much difference on the butt dyno but Im sure they are providing better spark than the stock 7mm wires. Plus I wanted red wires and thought that paying over $100 for some Nology or other types was ludacris since I'm not boostin.
BIGT94z
same witm me...however i had nologys and the dyno numbers wire less 150.3 than the stock wires for me (151.3)....the nologys are proven not to work....u lose spark in the ground strap
mazdaman
Car: 90 S13 CA hatch
If stock times are 15.7 for S14 and these are your mods and you're only a 15.1 at best...... What am I missing here??
ddgsxr504
mazdaman wrote:If stock times are 15.7 for S14 and these are your mods and you're only a 15.1 at best...... What am I missing here??
I have run a 14.9 once but I wasn't driving the hardest I could. What your missing is the fact that all those mods only put my car at 168hp and 154 ft lbs at the wheels, not to mention that my Zenki has 167,000+ miles on her. To make that clear NA/KA's suck to make power unless you are boostin.
Also I have no LSD of any kind.
Modified by ddgsxr504 at 3:14 PM 6/8/2006
BIGT94z
i ran a 15.78 yesterday and i have intake,accell wires, ngk plugs, header, exhaust plus i have 135 on the clock...no lsd a 14.9 is really good all motor for a 240sx...i do not beleive that a stock s14 runs 15.7's (probaly a professional driver cough cough) which we are not...so id say a good driver in a stock s14 could do 15.9-16 ish
john_t
Car: 1995 240 SX
I think you're pretty much dead on. I have a 1995 with a curb weight of 2832 (I'd never part with the sunroof). Not an SE, it's a stick. It does have a new clutch, and it's been rebuilt once, with no performance engine parts thrown in. I typically run 16.0's or 16.1's all day with almost NO variability. The fastest I've run was a 15.8 on a nice cool day in October with a great batch of fuel (all of a gallon and a half in the tank and no spare tire). I guess somebody could just have that really responsive ka that happens to randomly make an extra 10hp, but that isn't gonna bring times down much at all. That being said, I took my mother's (shoosh! don't tell on me) 92 coupe to the HS drags once, and while it felt quicker, the times were almost identical accross the board. I imagine with a nice breeze behind your back, you might get a tenth or so quicker:) I think that pretty much all the 240's I've seen out there there were admittedly bone stock pretty much ran low 16's with an occassional high 15.
BIGT94z
thank you john_t! so i take it u have been to kcir then? i totally agree with the temp. factor the track was 120 and the regular temp was 92. hopefully next time i go it will be cooler but i doubt it
mazdaman
This is a bit disappointing to me.... I am not bashing you or nothing, don't get me wrong here... But this bites.. What's the car's weight? Could it be these motors don't respond well to upgrades? I am looking into a KA24DE swap as opposed to a JDM route..
Should I re-think my gameplan?
naed240sx
Car: .....
ddgsxr504 wrote:I have run a 14.9 once but I wasn't driving the hardest I could. What your missing is the fact that all those mods only put my car at 168hp and 154 ft lbs at the wheels, not to mention that my Zenki has 167,000+ miles on her. To make that clear NA/KA's suck to make power unless you are boostin.
Can you post a dyno?
BIGT94z
ddgsxr504 wrote:168hp and 154 ft
whys ur torque so low my dyno was 153.2 hp and 164.8 ft
ddgsxr504
BIG_T wrote: whys ur torque so low my dyno was 153.2 hp and 164.8 ft
I could have my numbers mixed up. I might be quoting my numbers from before the port and polish. It has been so long. I am not really infatuated with HP/TQ. I quit adding power mods to my car like almost 3 years ago.
naed240sx wrote:Can you post a dyno?
I'll try and find it. The last time I dynoed my Zenki at the end of 2003. I'm sure it's with my other paperwork. I'll post back if I find it or not. I dynoed it at Dynamic Autosport in Irvine, CA.
