Is this my front differential?
suobs
Car: 1994 Nissan 4x4 Hardbody King Cab
Wanting to replace the gear oil in my 1994 4 cyl Nissan Hardbody King Cab 4x4 pickup. Is this my front differential?
Two views shown below - front facing forward (I think it shows the check/fill plug) and bottom (I think it shows the drain plug). Both photos taken from under front bumper. Thanks!
Reason: Fix image links
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Yes, that is the front diff.
whomadewho
Car: 1997 Nissan pickup
If you change the gear lube in the rear differential make sure you use the correct lube. A lot of the 4x4 hardbody used posi traction rear differentials.
suobs
How do I tell if the rear differential is posi-traction?
Rev_D21
Two ways: 1) there will be a sticker on the back of the housing indicating to use LSD fluid only or 2) jack the rear of the truck up and turn one wheel while the truck is in neutral. If both wheels spin the same direction you have limited slip. If one wheel turns the opposite direction you have an open diff.
suobs
Limited slip = posi-traction?
Rev_D21
Yes that would be correct.
