sorry, keep forgetting it doesn't pop up next to my name... It's a 95 240. All stock, 5 speed car with SE package (tilt wheel, cruise, air bags, no hicas or ABS)
I checked all inside the driver's kick panel where the fuses are. All relays in there are marked as standard 5 pin switching relays. I also checked everywhere I could see near the steering column, and other than some seriously chingis looking alarm wiring all appears normal, but no flasher relay. I traced the steering column harness back from the column as far as I could over the AC ducting toward the fuse panel and didn't find much either.
There is a small two pin device mounted near the clutch pedal that has a hole in it for sound to come out. I'm figuring that is the door beeper. It is orange in color and held down with a 10mm head bolt on the clutch pedal bracket.
I'm at a loss on this one, my next guess is to just start disassembling ****, which I'd rather not do just yet..
Thanks for the help
NISTECH wrote:I was gonna try to figure that out for ya but it seems you havent posted what kinda car you got.
