is this manifold top mount or bottom mount ??
matt black
Car: 89 Nissan 240sx ka24de
http://cgi.ebay.com/ebaymotors...28898
SimpleEnigma
Car: 1992 240sx Coupe
im pretty sure thats a bottom mount manifold
Craving4Boost
Car: 91 240sx fastback
its sh*tty mount...haha jk yeah its bottom mount
matt black
thanks guys for the quick answers.. i searched but all i really came up with is SR stuff
Structure240sx
yea its bottom mount, would make for an easy turbo kit using sr FMIC, turbo elbow, downpipe, turbos
one kid i talk to has that manifold first with a stock sr t25 and now with a gt2871, doing great
matt black
so a sr fmic would bolt right up to this setup ...ie bottom mount mani, sr t25 with elbow and down pipe
Snowflakedrifter
Car: S13 Coupe
yep ... i bought that mani ... it's CHEAP in price, but much better quality than ssautochrome's manifold. The ports are nice and smooth ... and the reason you can use sr stuff is because this manifold place the sr t25 or t28 in the same place as it would be on the sr. So you can use sr dump pipe, downpipe, and all the intake piping. It makes for a fairly inexpensive setup ... and it's good for about 200-210 hp with sr 370 injectors and stock SMIC. Don't listen to the critics ... 6 months ago people laughed at me when i dropped the idea of using a t25 on a ka, but it's a great setup. The turbo spools up fast and holds boost threwout the rpm range. GOOD LUCK!!
hint hint ... buy it now
matt black
thanks .. its sounds like we are going to have the same setup... really i am only looking for a low boost setup and i dont want to spend alot of money on a kit... thanks for all the good replys ..
what does the smic max at HP wise??
Snowflakedrifter
Car: S13 Coupe
you'll be fine if you run low boost ... i'd stay at around 7psi ... that's plenty with a t25 and stock side mount. I'm gonna be running a BB T28 pretty soon ... just needs to be rebuilt.
