lbs/hour = [450X0.65]/[4X0.85] lbs/hour = 292 / 3.4lbs/hour = 85.882!
with that calculation, you need 875CC injectors to support 450HP. that's for the worst BSFC possible and 85% duty cycle.
i've always used meggala
http://www.meggala.com/injectorscss.htm and just taken into account duty cycle.
cc/min = HP x 5cc/min = 112.5 x 5 (HP per cylinder (450/4) cc/min = 562.5
but that's at 100% DC, so divide by DC. 562/85% (85 is pretty high for top feeds, but side feeds can be driven 100% since they're cooled by the fuel) = 661cc.
it's a huge difference between the two calculations. would you run 675cc or 875cc injectors in a 450HP car? i have one friend with 650's in his 285whp AE and another with 750's in his 417whp SRT-4. who's closer to the ragged edge? i dunno, it depends on the school of thought i guess.
you want to try 450CC injectors? lbs/hour = cc/min / 10.2 = 44
reverse the calculation:44 = HP [X 0.65] / [4x0.85]44 = HP [X 0.65] / 3.444 X 3.4 / 0.65 = HP229 = HP
of course, if our BSFC were closer to 0.55, it would be more like 272 HP, which makes sense since many people use 450CC injectors in 260-300 hp cars. but for your setup, 450cc's are nowhere close.
