PROJECTRB240SX wrote:ABS SUCKS..... I WOULD RATHER NOT HAVE IT THAN HAVE IT AT ALL. I'VE HAD TOO MANY BAD EXPERIENCES WITH ABS, AND I CAN OUT BRAKE MY FRIENDS ABS FITTED PORSCHE WITH MY STOCK BRAKES.
So what are your bad experiences? If your ABS is working properly, it WILL stop your car faster all other conditions equal. Consider these points. A car does not distribute weight perfectly left to right. Nor is it built with a perfect brake bias for every condition. The more traction you have for braking, the more front bias you need as more weight gets transferred there and away from the rears. And if one side is seeing more weight loading then the other, then one side will lock up first. In fact there will always be one tire that locks first before all the others do. This means, if you are threshold braking, you are essentially threshold braking the limit of the first tire that will lock up. The other three tires will still have some potential to help slow the car, but it won't be used. With ABS, when you get to the point of lock-up with the first tire, it will begin it's magic and keep it from locking so you can apply more pressure. Then when the second tire hits the threshold, it activates the ABS in that channel. Now you can use more of the third tire's available traction to help stop the car. So on and so on.
And in a road race/autocross this becomes even more pronounced. You can not only decelerate at a quicker rate meaning you can start braking later, but you can also carry more speed into a corner since the ABS will keep the overloaded tires from locking and be able to use some of the available traction in the tires that are not making full use of it's available traction. And if you know anything about road racing, the braking is very, very important to setting up passing manuevers. Being able to brake better, will allow you to come inside the turn hotter and take the inside path, forcing the person you are passing to take a poor line and allowing you to pass.
You can ditch the ABS if you want, but if you're competition has it, and they knowwhat they are doing with it, then chances are, you'll be finding yourself behind them very fast.
