Yes. These two have already destroyed mustangs and other Fords.Focusedintntions wrote:you should be ok...just remember from now on in the back....
yeah i just read mine it says 900lbs maxSentientbydesign wrote:Not sure if the Sedans are as balanced as the coupes, but if so, then you shouldn't have any problems.
The coupe springs rates are the same for the front and rear, which means that loading extra weight there vs the front wouldn't do any damage.
The thing to worry about is total weight for the vehicle. On the door pilar there's a table that says what the maximum weight is for the vehicle. My 05 coupe has a maximum passenger/cargo weight of 750 which isn't much for 4 people and some junk in the trunk.
Crude? Yes. Taste-less? Yes. Do I think anyone should ever get that fat? HELL NO! Do I think women who chose to get that fat and then parade in bikinis should be tormented for their stupidity?....*crickets*W661335PF wrote:So at the risk of being banished or getting much hate mail from others, I have to say that I find the "fat chicks" and obesity humor a bit tasteless, ill-chosen, immature and crass. While I'm not obese, I still think we can do better than this here.
Obesity is not necessarily a choice. On our practice we see obesity in a more holistic way-- as a result often of genetics (obesity usually runs in families and is hereditary/genetic), at times it can be neurologically based (e.g., hypothyroidism, Cushings syndrome, hypothalamus being damaged, etc.) and often has behavioral and psychological factors. Why not get our joys elsewhere as opposed to being cruel and crass.Sentientbydesign wrote:
The spring rate in that of itself are not important. Given the design of the G's suspension, the rear springs have to be stiffer than you might find in the rear of most vehicles (relative to the front spring rates). The G35's use springs that are at about the midpoint of the LCA. Most vechiles locate their springs closer to the wheels. The effective wheel rates from front to rear are going to be much further apart then the spring rates themselves suggest.Sentientbydesign wrote:Not sure if the Sedans are as balanced as the coupes, but if so, then you shouldn't have any problems.
i doubt my shocks or suspension will bottom out. at least i hope not over 100 pounds. but ill be super extra carefull when im dirving with people in the backC-Kwik wrote:
That said, it's doubtful that an additional 100 lbs in the rear is going to be a huge cause for concern. Accelerated wear may occur, but that is dependent on many factors. I would be concerned though if the extra weight caused the shocks or suspension to bottom out. In which case shocks can blow or other problems can arise...
Well, you're about 1/3 of the way there. And no we don't classify everything as a medical illness, we see choice in many things and even see some of what passes as mental illness as little more than irresponsible, immature behavior and a real failure to grow up and face reality.Sentientbydesign wrote:Here's my take on obesity.
I chalk it off to stupid choices in ingredients (not the consumer's fault) like High fructose corn syrup, hydrogenated oils, and sugar substitutes (lets take this to the political arena if you want to argue with me on the last one).
And lack of self control. I'm 65lbs overweight on a height chart. And around 30 lbs overweight realisticall (I don't think I should be 6'3" and weight 185 lbs like the chart suggests). I have been at MY ideal weight and my overweight-ness is nothing more than poor diet choices and a lack of physical activity (40 hours sitting at a computer and another 14 on the weekends driving around).
The current medical trend is to classify every condition as an illness. It is true that there are many illnesses that weren't classified 100 years ago and should have, but there are plenty more that shouldn't be illnesses at all and individuals should take responsibility for their issues.
Well, the suspension isn't affected by rotational mass. It's affected by unsprung mass. Rotational mass affects the ability for the engine to accelerate the vehicle and the brakes to decelerate the vehicle.Focusedintntions wrote:bigger rim = more rotational mass = more work the suspension has to do to keep the wheel/tire on the ground.
G'd up...don't worry....the stuff in the back may take off like 3k miles off the life of your shocks....if you hit a really big hole and it blows the shock...it would have blown regardless of that stuff.
