Is this an S14 alternator? If so can it be used in S13? Pic
Cgeigert
Car: 1989 Nissan 240sx
I bought this thinking it was for s13 sr20det, but from searching the part number it looks like it's from S14. It also looks a little different from the two on my cars. Is it from S14 and will it work on S13 sr?
Seishuku
Car: 1987 Nissan S12, 5-speed, SR20DE+T 50trim T3@15PSI, Megasquirt 1 029y4
It's an S14 alt, but I don't know if they're interchangeable... My guess would be yes.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I don't see why it wouldn't Nissan didn't change the alt going into the S14 AFAIK. I know it's very easy to use a KA alt on an SR, only the mounting tabs are different. Hell, I've seen people use Quest alts, which are a different amperage output.
Cgeigert
Well from research I've seen posts where people say S14 alt can work with minor mod, and others say the later year 96+ s13 redtop/blacktop came with s14 alt. I don't want to deal with any wiring modification, I'm trying to fix that kind of stuff on this car. Already pulled out like 5 pounds of wiring crap done to the car. This alt looks a little different than the ones in the cars so I'm gonna pick up a for sure s13 sr alt just in case this one doesn't fit.
PyR0NiAk
Car: S13 SR W/ T2 GT3071R .86AR, JWT S4 Cams, 810cc Injectors,Z32 MAF, JWT tuned ECU 87mm 9:1 Compression CP pistons, Manley Rods
If you don't want to try installing the S14 one, go to your local parts store, and pick up one from a KA. You just have to drill out the bolt hole and swap the pulley....
Cgeigert
Already have s13 sr one on the way.
Cgeigert
The s13 sr alt I got was bad so I ended up using this one. It is slightly different from s13 one but it is straight bolt on, you just have to file out the inside of the + connecter. Other than that works great.
