90 DGRZ »
https://forums.nicoclub.com/90-dgrz-u34570.html
Tue Jan 08, 2008 10:34 pm
today i got new rear tires.
don't ask why i did this, but cruising anywhere above 60, when i wiggle the wheel from side to side (2 inches left n right, about) the car seems "loose". it seems like only the front of the car is moving in the direction its supposed to go, then the rear seems to tag along late. it's hard to explain without showing you - but it seems like if i wiggle the wheel bigger, i can feel even more distincly how much later the rear comes around and grips. this is most likely also why i have "snap oversteer" on this specific car.
here's whats up. i completely changed the rear subframe of the car, and put back the arms and did a eyeball manual alignment by measuring. i know this is by no means a real alignment. what does it sound like my problem is? too much +toe? caster? camber? Preach and i'll listen.
sidenote: i have 25mm spacers in the rear.
