Is this all that I need
Doya
Car: '95 240sx KA-T
Is this all the stuff that I need to turbo my ka. I just plan on putting together a cheap setup.
*T3 Turbocharger*T3 Manifold(w/ external wastegate)*Oil drain and return lines*FMU*Manual Boost controller*Turbo timer*FMIC I don't plan on running alot of boost. I just want to create a basic setup now, and upgrade later Thanx in advance
Tyler
Car: 1989 240sx HB/1992 240sx coupe/1998 s14
no, you need a downpipe, external wastegate with like a 7psi spring, you can ditch the boost controler cause you wont be able to turn it much past 7psi anyways with only an fmu. also you need a walbro 255lph fuel pump, a bov, and then set aside like 1k(seriously) for the random s*** that is garenteed to pop up when you turbo a NA motor
Doya
Car: '95 240sx KA-T
So if I use a FMU, do I still have to upgrade my fuel pump. Also, what kind of FMU should I get 12:1, 10:1, or 8:1
Modified by 95ka24de_zenki at 10:49 AM 6/21/2009
1SickSilvia
Car: 1992 Nissan 240sx vert
Please read the stickies at the top and do some research, ohh and dont forget doing a cheap setup does not always = reliable setup. So decide on your goals and your budget and go from there.
WDRacing
For a bare bones setup you've got a good start. I also suggest swapping in the 255lph pump. It's just alot better then the stock unit. But if this is for an S14 you may be ok. They have a better fuel pump and ignition then the S13.
No need for a BOV either. They lead to lots of problems and aren't really needed for such a low boost number. If you do get one, just get a Bosch Bypass Valve. They are like 30 bucks and work very well.
WD
Doya
Car: '95 240sx KA-T
Thanks alot WD One more thing, will a 12:1 FMU be too rich. Thanx
WDRacing
8:1 FMU is the best. I recommend using a known good brand like Vortech.
WD
joenismos15
Car: 1995 Nissan 240sx SE
Hey what part of MD are you in? does your zenki have black rims with chrome lip? i think i saw you on Route 1 awhile ago i was the goofy guy that waved!
WDRacing
Was it the cool "nice car wave" or was it the "hey look at me...over here" wave...lol.
joenismos15
it was the hey nice car i hope he doesnt think im so old pedoph:le kind of wave.
WDRacing
27 aint old...
I'm a certified dirty old bastard at 34
joenismos15
I feel 40 if thats of any consolatory value
Doya
Car: '95 240sx KA-T
No man, that wasn't me. I live in southern MD. I have a red zenki with a faded roof and steelies. Wish that was my car, sounds like it looked pretty sick
