Now that you mention that I see exactly what you mean! I was sitting in line at White Castle (it was a fat night for me) and I could feel the slight vibration from the fan clutch engaging.fleurys wrote:It could also be when the radiator fan starts... I know mine does a slight vibration when it starts and I have learned to recognize it when it happens... If you really keep attention, you can sens it start then stops... if it is the fan, then you should get this alot more when it is hot outside....
If you take good care of your Pathy then I'm sure there's nothing to worry about.iPath wrote:No, RPM's stay constant when i feel the vibration. I have noticed it a little more noticeable in the past few weeks, and it has been getting hotter out. Hopefully it's the fan
May also be your A/C compressor cycling on and off, along with the fan.iPath wrote:No, RPM's stay constant when i feel the vibration. I have noticed it a little more noticeable in the past few weeks, and it has been getting hotter out. Hopefully it's the fan
