Jesda »
https://forums.nicoclub.com/jesda-u7038.html
Sat May 20, 2006 1:37 pm
After replacing two injectors, I put everything back together this evening (rather hastily, my poor back) and started it up. There's still a bad misfire.
Could my problem be a vaccuum leak? I thought vaccuum leaks (like from a bad intake gasket or broken hose) caused high idle. The idle RPM is where it should be, but its very rough throughout the rev range with an obvious misfire. I'd say its a little worse than before.
Before, it was rough at low RPMs but smooth enough on the highway, symptomatic of a dead injector. Now, its through the entire rev range. I didnt bother leaving the driveway.
Would compression testing determine if there was a burnt valve or something severe? Hopefully its minor.
Thanks.
