Lakai5567 »
https://forums.nicoclub.com/lakai5567-u215277.html
Tue Jan 29, 2013 4:13 pm
Hey all
Since I made rice of my ka last summer I have been on NICO and other forums pretty much daily since I've never done a swap before an basically I've started an account here to ask this question lol
Motor is pretty much just a proper, stock CA18 swap.
Fmic
Walboro 255 pump
Intake
Hks wastegate (for t25g)
Boost gauge
No exhaust....( Yet) It's a open a/m elbow that's it!
So anyways, after installing the new actuator the car pulls solid 16 psi at wot and a good roll on is where I like it (around 12-14psi)
I'm not convinced that my motor enjoys it as much as me...well...close anyways
So my question is this
Without upgrading maf, turbo, injectors, tune and map etc would setting the base fuel pressure slightly higher (5psi) with an adjustable fpr be a "good" idea, as opposed to leaving the stock reg as it is right now, stock lol
I've got a fpr to install if it is even worth the effort, but I don't honestly know if this is an acceptable(ish) way to run higher boost....compared to leaving the fpr stock, say.
I would think it is ok since maybe a little rich idle and bad mpg could result at worst
Ps bought motor set from Japan Star Motors, not a bad place to deal with either
