WDRacing »
https://forums.nicoclub.com/wdracing-u3125.html
Sat Dec 13, 2008 6:33 am
I don't know what your goals are for the near future, but there's NO need for new pistons or rods until you goals reach past 350. Up to 350 the stock internals will be more then adequate. So it's just wasteful spending if your power goals are small. To bring this into perspective, you'll need a new turbo and an entire new fuel system and management system before you'll need to worry about over stressing the stock parts.
Like 480 said already, concentrate on tuning first and foremost. Then get a better turbo and bigger injectors.
If you're rebuilding just to have a long lasting reliable motor, then just do a basic re-ring job. By that I mean new piston rings, new bearings, new oil and water pump, new gaskets etc. Felpro FTW...cometic FTL.
Head studs with a T25? GTFO of my forum with that BS
WD
