Is this a normal oil pressure reading at idle??
swiftstylez
Car: 300zx
Looks low to me. Just bought the car so should i be concerned? 92 300zx twin turbo bone stock by the way
car nut
Car: GT500.
What's it like when you get on it? During a cold start?
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
the stock gauge and sender can be flakey, stock idle readign should be aroudn 14 psi iirc, you can test thsi with a mechanical gauge in the sender port, cold start and higher revs will yield higher pressures, and as the engine bearings and rings wear the static oil pressure will drop
es.biggs
Car: 1990 300ZX 5sp NA
My gauge sits at 0 most of the time; Nissan really fubar'd this part of the car lol
evildky
06 Nissan 350Z GT
es.biggs wrote:My gauge sits at 0 most of the time; Nissan really fubar'd this part of the car lol
have you verified the reading with a mechanical gauge? are you sure you sender isn't bad?
alright2020
Car: 92 jeep wrangler with SBC
99 F250 with 7.3 on 25lbs
91 300ZX na>tt>na
03 G35 coupe
its more important that it goes up when you accelerate.... my original na motor would sometimes say about 0 at idle... then would hit 80 when hard accel... either way im using an aftermarket gauge now.... i never trusted that stock one completely
es.biggs
Yeah it's aroud 20-25 psi at idle. Not too shabby :)
mhedrick
Car: 94 300zx
mine sits at like 58 to 60 at idle after having all egr lines replaced and new injectors, water pump, new valve cover gaskets, timing belt etc etc....before it would sit at 20 at idle and now its at 60.....good or not?
es.biggs
I wouldn't be worried about it. That's kind of high, but if it's from the stock gauge, I wouldn't even trust it.
vitaminZ
Car: 1990 Nissan 300ZX
swiftstylez wrote:Looks low to me. Just bought the car so should i be concerned? 92 300zx twin turbo bone stock by the way
Thats funny i was thinking the exact same question yesterday, but my Z has always been like that ( at idle ), but once you push the gas ( or under operating pressure ) it will move. :gapteeth:
