is this a good spot?(vacuum block)
240freak88
Car: 97 s14
installed a vacuum block and for some reason its not strong enough to open my BOV ,also i might have a vacuum leavk did the carb cleaner trick and cant find nothing....my questions are is this vacuum block in a good place?(dont mind the black vacuums,their teed into eachother because i didnt have caps)
also when i removed my EGR ,i was left with one open vacuum i plugged with a screw scene in this picture,but now using it for my boost gauge ..just figured id show incase i was doing somthing wrong..any ideas?thanks
neverlift
vac block looks fine, maybe some heat protection..
I would run the boost gauge off the vac block.
superDorifto
Car: 1997 Eclipse Spyder - AWD/5spd swap in progress
1995 Q45 - 5spd swap in progress
1984 200sx hatch(KA-t swap) - 355WHP
1991/1993/1995/1997 240s - Dead
1982 200sx hatch - fixed/scrapped
placement of the block shouldn't affect the ability of the unit to build usable vacuum. If its not pulling enough, check to see that
1 - your waste gate isn't hanging up/seized.
2 - That you dont have a leak somewhere in the system (This is the most likely reason)
240freak88
Car: 97 s14
superDorifto wrote:placement of the block shouldn't affect the ability of the unit to build usable vacuum. If its not pulling enough, check to see that
ok cool,well ive done the carb cleaner trick and couldnt find anything..i heard about blowing cigerette smoke in to the brake booster?while its on?or off?any other ideas on how to find it?
