Is this a good setup?
sunnys14
Car: S14
bone stock s13 blacktop555cc injectorsz32 mafenthalpy ecuhks step 1 264's s14 t28 @ 17psiturbo manifoldfull exhaustFMIC
are the hks cams a good match up with the turbo? how much power do you think i will make?
CoupedUp
Car: 1993 Coupe
cams for a setup like so really isnt too important IMO. But that turbo wont last too terribly long at 17 PSI, also it would be way past its efficiency range.
Other than that would be a good setup.
sunnys14
Car: S14
i thought the turbo's efficiency range was 14-16 psi?
CoupedUp
Car: 1993 Coupe
sunnys14 wrote:i thought the turbo's efficiency range was 14-16 psi?
So you wanted to go past it? No AFAIK ALL Nissan turbochargers are good for about 14 PSI at most. Minus VG series.
sunnys14
Car: S14
really? s15 turbos can hit 18psi and still make power.
sr20usmcswim
Car: Nissan 240sx 1990 hatchback
I had that setup with 256 and 264 with uras manifold and i was pushing around 300whp at 14psi
fstsil80
are you goin with this turbo to be cost effective?
why not go with the big 28, i think it flows a little more and cost about the same.
sunnys14
Car: S14
the reason i chose this turbo because i already have it.
kriskouki
Car: 240sx
okay for a quick startup
