solaire »
https://forums.nicoclub.com/solaire-u232456.html
Wed Mar 05, 2014 10:41 am
For the price it better be. The company seems to have good reviews. Have you priced it through Nissan? May be the same price to take it apart, find the failed parts and order just what you need through Nissan then you know they'll be good quality. If that's out of the question then i'd go for them.
The trans is easy to rebuild also. I've only had issues with the nissan 5 speeds in the older pickups and it was only input shaft bearings making noise (easily mistaken for a throwout bearing) Take bellhousing off, tailshaft off and you can pretty much put the center in a vice and disassemble the shafts there. That's how nissan shows you to do it in school. You're going to need access to a press to replace some of the syncros on those shafts.
