BadQ45t »
https://forums.nicoclub.com/badq45t-u300.html
Sat Feb 25, 2017 10:52 pm
$2,500 for that car is a good deal. As stated you should expect to replace the struts and shocks and the tension rods, which are not expensive. There is little to no aftermarket support for this car, but shoot $2,500 is the price tag on a tech package on a new Infiniti, not a whole car!! My 97' has 110k on it and i have done the suspension with coil overs, tension rods replaced and the steering rack was leaking so I had that replaced. Engine wise knock on wood the car still run as smooth as silk. I took the old radio out and put a Pioneer double DIN radio in that does streaming and added bluetooth connectivity for about $500 installed out the door.
At that mileage pretty hard to get hurt, just know if they owners are still running the 20 year old suspension that is going to need to replaced and you cannot find Monroe, KYB, etc down at your local parts store. It is OEM or coilovers. Also know that this is only a 4 speed transmission so gas mileage isn't stellar and you will need to feed super unleaded..if these are issues you should move on to a newer Altima or Maxima that have more aftermarket support and don't require super (new Max does drink super)
