goody90q45 »
https://forums.nicoclub.com/goody90q45-u31761.html
Sat Jul 04, 2009 4:38 am
From the owner's description the engine runs but cuts off after a minute or so. It's probably going to be MAF or fuel delivery (FPCU) related.
If the engine is stalling or seaching for a steady idle RPM then it's probably MAF related. Does the MAF connector wiggle up and down more than 1/8"? Pull off the connector and look at the pins. Any green corrosion? If you have it here it's on many other connections on the engine. Clean up the corrosion, tighten the pins (should look like the middle pin in the pic), coat with dielectric grease.
The owner has replaced the fuel pump but he could easily have waited too long and also damaged the FPCU. It's mounted under the rear deck and can be seen (and unplugged) through the trunk. It's in the background in the pic. Reach in and unplug the FPCU. Any signs of burning or melting? Bring an alligator clip jumper with you and jumper from the pin shown in the pic to a chassis ground. This will bypass the FPCU and run the fuel pump in high speed only. If this solves the problem you've got a bad FPCU.
Since the engine does start and run chances are darn good that it's one of these two things. Good luck.
