saw192837 wrote:Took 1997 J30t for alignment, Firestone said my rear brakes needed replacing. Says
Right Rear Break "RR" is 85% worn, and that the caliper was allowing that bad to grind away on the wheel? Something like that. The other brakes they listed as being 50% worn.
They want me to buy "R LT CALIPER" $175x2 "R PREM NON ASB PADS $139 "R DISC BRAKE ROTOR $146x2 LIFE TIME REAR DISCBRAKEJOB (Labor) $120
BRAKE SYSTEM FLUSH/FLUID/LABOR/BLEED ABS: $92
Total est. $994
I asked what will happen if i dont repair it, they said that the rear brakes would stop working, and eventually "it will lock up on you"
Fair price?
No, not a fair price. I bought the expensive pads this last week and they were $42 after tax. I doubt your calipers are bad. The bolts that hold them on need to be re-greased.
It took me about 30 minutes to change the pads and most of that was jacking the car up and getting the wheels off.
Buy a set of pads, and find a good friend or mechanic that you TRUST to put them on. Offer your friend some money, food, etc of your choice for his help. I would probably do that kind of job (including flushing the fluid) for like $50 for a friend.
