Post by s1ndicate » https://forums.nicoclub.com/s1ndicate-u23359.html Fri Aug 26, 2005 6:18 pm
Post by naed240sx » https://forums.nicoclub.com/naed240sx-u28231.html Fri Aug 26, 2005 7:08 pm
umm.... how much is it lowered, what kind of coilovers, what are they set at? Obviously, unless crossweight is going to be different, but it should not be enough to cause anything that you can feel. I just put some kts on my s13, lowered it about 1.75 up front and 1.5 rear, and It seems to be on the oversteering side of neutral, turning both ways. Are you confidant that they did a good job of aligning your car? After installing the co's, but before getting my car aligned, it understeered like mad, because it had excessive toe in(I had replaced tie rod ends), and it had positive camber up front. Im not really sure what your problem would be, but im pretty sure its not a weight issue. I would look into the alignment.s1ndicate wrote:I just installed coilovers, lowered it, etc. etc. Got my alignment done. One thing I have noticed is going into a left turn hard it wants to oversteer, but going into a right turn hard, it feels real good.
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
