Is this a common problem with z32 and how do i fix it
eclipse069906
the car stall periodically when the rpm's drop too fast
is there anyway to fix this is it a vaccume hose or what
thanks alot
Fox213506
Car: 1990 Nissan 300zx N/A 1995 Motor Swap
It should be a common problem i have it happen to me once in a while.
Zak427
Car: 93 2+2 Twin Turbo
that is iether a fuel or air problem more than likely. first try the cheap easy stuff. buy a can or maf cleaner. spray out your maf sensor. make sure running high quality high octane gas, next would be a fuel filter....but keep in mind many things are tied in on this car. i had a speedo problem which knocked out my power steering....
Rex
Car: None
eclipse069906 wrote:the car stall periodically when the rpm's drop too fast
thanks alot
Is the car an AT?
Either way, I'd guess it's a vacuum leak
Canyoncarver
Car: '93 300zx
Does it happen when you're rolling along at speed, or when the car is sitting still?
Do you have the stock air box or aftermarket cone filter?
eclipse069906
its got the stock air box and it's only when u go to stop and the rpms drop real fast
