Is This a CA18DET ECU?
rico05
Car: 1992 RMS13 w/ CA18DET
Got to looking, and my ECU has "CA18DE" written on it by the shipper. It has big 98 on it, and then below that it has23710 36F00MEC-D*03 D 8630
The * is scratched so I can't read the character. Any thoughts?
pulsar gtr
Car: NISSAN VEHICLES
hum, I might be wrong, but I believe 79 is RWD ca18det and 78 is AWD ca18det, but not 100% sure, I believe this subject has been discussed in the past, give the search a try and see what kind of results it throws back at you.
I have couple ca18de ecus and couple ca18det at home, I will check for you when I get there
PULSAR GTR
PacManVR4
I will check mine when I get home seeing as I have 2. The good thing is that the right ecus are cheap.
rico05
Well, I looked on eBay and there is a Mine's ECU that has a 98 on it. And there is another ECU that has a 99 on it.
pulsar gtr
Ok, I check both ca18de ecus and one says 28 while the other has 27 on it, mind you that these came off a nissan pulsar from Canada not Japan.
PULSAR GTR
rico05
Ok, so my 98 IS a RWD then?
pulsar gtr
Don't know about the 98, both my ca18det ecu are 78 and 79, check with other memebers and see what theres say on it.
Good luck,
PULSAR GTR
boost_boy
98 is a RWD ECU!
Dee
rico05
Dee to the rescue! Thanks man.
