is this a bad injector?
sunnys14
Car: S14
i just bought a set of SR 370cc injectors off someone in the classifieds. the guy lived near me so i went to pick them up. i examined them and they looked fine to me. purple top injectors, o-rings looked good... it was dark when i got them. i paid him $75 bucks and i drove home. after i got home, i looked at the injectors again and at the TIP of the injector where there looks like 4 tiny plastic teeth curve in at the tip of the injector... one of the teeth is broken off! is this injector still good to use or will it leak?!?!
virus77
Car: 95 S14, 71 240z, 97 e320
still good, dont worry. I forget what those are for but Ive seen alot of injectors that way, i believe I may have ran them back in the 370 cc days.
fiznat
Car: Grown up :(
Arent they there to help spray the fuel out over a wider area for better atomisation? (sp)
Structure240sx
they are called pintle caps. one of the four wont be a problem. never was for me when i used side feed injectors.
check out our sponsor destcheworks. he will clean, flow, balance, replace orings and pintle caps for about $50 with 1-2 day turn around. he did this for geo on his 370cc injectors. one of his injectors was slightly leaky and he fixed that also. definitly worth the money
GEO
Car: 95 240sx KA-T
i will attest to that
Structure240sx
geo, was very impatient about it also.
here is his signature in every email he sent about getting the injectors done
jewish mafia btw
ceniack
Car: 1992 240sx Coupe
1993 JDM Nissan Caravan
2011 Subaru WRX STI Hatchback
2012 Subaru Impreza Hatchback
yeah, if you all need injectors cleaned, we are the place to do it (infact i remember cleaning and flowtesting a set of 370cc injectors, but never really put 2 and 2 together)
we are also currently running a nico special on our injector service
zerothread?id=138400
glad you were happy with the service.
and to sunny, i wouldnt' be worried about the pintle cap having a tooth being broken off, but i would at least get it and the o-rings (if you didn't do it alraedy) replaced as it is a bad idea to run used o-rings, you can get the o-rings from us, i will have to ask dave if he would send pintle caps seperatly as well though since this is usually somethig we replace with our injector service.
also, make sure to lube the o-rings before installing the injectors
if you have any questions you can e-mail me @ [email protected] or you can get ahold of david at [email protected]
K240
Car: 1993 240sx
What kind of lube should you use when replacing o-rings?
onosqv
Car: '92 240sx Vert
K240 wrote: What kind of lube should you use when replacing o-rings?
Lots of ppl like to use vasaline... some use motor oil. I used motor oil since it was more readily available... and I didn't want my dirty *** hands messing up the vasaline bottle.
ceniack
i believe we use a silicone lubricant at work, i will look at the tube tomorrow and find out for sure what it is.
