This right here. A/F ratio is only one factor in a sound running engine. Timing is huge. Without the proper support the motor can be on the stock timing map. While you might not be running dangerously lean, the timing is to far advanced for the A/F mixture. You can still have knock and be running super hot exhaust temps when timing is to far advanced even while in a relatively rich A/F ratio such 12.5. or 13.PyR0NiAk wrote:Just because it's not breaking up, doesn't mean you're not doing damage. While I believe what you're saying, I also have to say that I believe your friend got lucky...
It seems every other car in my home town ends up with holes in their pistons because they don't run enough fuel. Their story is always the same... "It was running great!"
then what exactly is the maf there for??rc1honda wrote:This right here. A/F ratio is only one factor in a sound running engine. Timing is huge. Without the proper support the motor can be on the stock timing map. While you might not be running dangerously lean, the timing is to far advanced for the A/F mixture. You can still have knock and be running super hot exhaust temps when timing is to far advanced even while in a relatively rich A/F ratio such 12.5. or 13.PyR0NiAk wrote:Just because it's not breaking up, doesn't mean you're not doing damage. While I believe what you're saying, I also have to say that I believe your friend got lucky...
All a MAF does in interpret metered air as load. So if its sucking in a lot of air it tells the ECU that it under high load. And will pull timing when the load gets to high in the stock ecu range. But these are not factory parts we are talking about. And a MAF is a rudimentary load meter at best. Thats why all big power setups use Pressure MAP sensors instead, and air intake sensors to measure load and intake air temps. MAFs are unreliable when pushing any kind of real horsepower. If your depending ona MAF to pull timing in order to save your engine you better have a short block ready to build on standby.ciscos13 wrote:
