I found a rebuilt rack for $300-600 depending on where you get it. 4 hours labor isn't too bad, but the shop I brought it to seemed to give me the "we don't want to do it" price. But you're right, this could be a situation where you replace 1 thing, and it leads to 3 more.VStar650CL wrote: ↑Tue Dec 24, 2024 6:20 amIf you're not able to DIY what it needs, resell it. It's only $2500 blue book when it's healthy, and the repair labor will eat you up if you need someone else to do it. For a DIY, you can get a pair of CV's and a new China-cheap rack online for under $500 total. The rub is, the rack alone is a 4 hour job, and add a few more for the halfshafts, then an alignment. So you're into, say, $900 labor for a shop to do it, and that's assuming they don't find anything else broken while they're in there. Not worth it unless you love the car and want to make a project out of it.
This is the easiest thing to fix. There are other issues but the rack should be held firmly in place by two mounting brackets and a pair of insulator bushings. Replacing these bushings will make a huge improvement to your steering issues. Nothing needs to be removed but 4 bolts holding the brackets in place. The rack moves because the bushings are shot. Nissan part numbers 54444-0W000 and 54445-0W000 is what you need from the Nissan dealer. If you simply can't do this yourself, the service time to have it done should only be an hour or less.DaysofThundr46 wrote: ↑Mon Dec 23, 2024 8:47 pmYou can move the front end tires left to right with your hands and see the bar just move freely.
Thanks for making that point. I assumed, by "see the bar just move freely", he was referring to the rack. If it is the tie rods freely moving, there is whole lot more involved.VStar650CL wrote: ↑Thu Dec 26, 2024 10:52 ameither the rod ends will move and the body of the rack will stay still (bad rack) or the whole rack will move (bad bushings).
Interesting. I wonder where they dreamt up a $950 quote.VStar650CL wrote: ↑Thu Dec 26, 2024 3:42 pmNo chance. The OE racks are discontinued, the only place you might still get one is Amayama in Japan.
Big +1. That includes the racks themselves. You can find very China-cheap ones on eBay for $140. I don't think I'd trust those to last very long.mdmellott wrote: ↑Sun Dec 29, 2024 4:44 pmThere is a market for very cheap replacement car parts that do not last beyond the limited 3mo to 3yr warranty they may have. Those parts are often purchased for a cheap fix before getting rid of the car. Many aftermarket tie rods fall into this, "let the buyer beware", category. The same can be said about aftermarket rack and pinion replacements. The mount bushings would have likely been, or should have been, replaced when the rack and pinion was replaced. Typically, aftermarket racks come with the inner tie rods and boots preassembled, and often the outer tie rod ends as well. The March 2020 tie rod replacements could have been replacements for those installed in 2018. Get a second opinion from another mechanic on what steering components are shot.
