BadMojo »
https://forums.nicoclub.com/badmojo-u5205.html
Sat May 03, 2003 4:12 pm
I'd pass on that car. The Bondo is most likely promoting a nasty case of rust under the spoiler (a common prob with the 240SX). Bondo is often used improperly, resulting in terrible cases of rust. It's not meant to be slapped on a car with a trowl, it's supposed to smooth out minor surface imperfections. It also has to be properly sealed from moisture, as I believe it's very absorbent.
I would be very careful with rust around the strut towers. Be sure that it's just surface rust. They are obviously important structural areas, and you don't want any weakness.
The water in the trunk might be coming in through your tail light lense covers. They might be cracked, or the gaskets are dried out and useless. Probably not a big deal unless you have rust in the trunk.
If the strut tower rust was surface only (it's hard to tell sometimes) and if it wasn't for the rear wing problem, the car might be a good deal. I bet if you take that rear wing off, you'll fnid some serious rust on the trunk.
Of course, this is all just my opinion. I haven't seen the car, and I could be wrong. Just be careful and don't make any snap decisions.
