Is there such thing called lsd transmission for the 95 s14 ka24det
stevethamson
Car: 95 nissan 240sx
one of my friend mention that all ka24det transmission have a long ratio, although i have no clue what he ment by that....all he said was that even though i'm running at 90 per hour on a highway and the rpm is still only at 4000....i dont know what he ment by that...he said that i need to look for a lsd transmission for my ka24det because it will make a huge different...i need answer please....
Hi Steve, welcome aboard.
First off, you need some new friends, because the one you have knows nothing about Nissans.
Quick corrections:
All transmissions in 240sx's are the same. You get an automatic or a manual, and that's it.
All USDM 240sx's had a KA24E or DE motor, not DE-T. The T signifies "turbo" and Nissan never made a factory turbo KA.
LSD = Limited Slip Differential. This is commonly referred to as the "pumpkin", or the gear housing between the rear axles.
No such thing as an "LSD transmission".
The Nissan LSD will make NO difference in gear ratios necause they are all the same. The only difference between an LSD and the differential you probably have is the LSD applies power to both rear wheels rather than one.
Those are the basics, now quit hanging out with that friend and start reading posts here - You'll learn a LOT more. Better still, invite your friend.
jamied311
Car: 91 Nissan 240SX Fastback
AZhitman wrote: now quit hanging out with that friend and start reading posts here - You'll learn a LOT more
sidewards
Car: 95' 240sx sr'd, 00' Sierra 1500, 94' cbr600 'fighter
Your freind is a tard. If anything the final ratio is pretty short in 240sx's. I run around 3K @70mph. most 240sx se have a limited slip diff(LSD) like mine. An LSD swapped from a J30 will decrease your rpms because the gears are different not the lsd mechanisms.
sidewards wrote:An LSD swapped from a J30 will decrease your rpms because the gears are different not the lsd mechanisms.
Not enough to notice.
Stock 240sx = 4.08:1J30 VLSD = 3.96:1
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
stay away from people that own hondas.
mmm240
Car: 95 Nissan 240SX KADE-T
94 Toyota Pickup
91 Mitsubishi Galant VR-4
03 Toyota Matrix XR
sidewards wrote: most 240sx se have a limited slip diff(LSD) like mine.
only 240's with hicas have lsd's correct? but i am 99% possitive that just cause it's an se it has an lsd is not a true statement i beleive maybe the 97 up se 240's have lsd's as well?just trying to give the newb accurate info
sidewards
yeah, I said most not all.I'm pretty sure the 97's have lsd as an option.
zukitek
Car: 95 240SX-SE
it s my understanding that canadian SE's and SE's with ABS have VLSD ,or have the best chance.Is this the size of it or no?
Ricky
TurboS14Zenki
Car: 1996 240 SX
On the 95 to 98 to have LSD you have to have Anti lock brakes but not every car will have LSD if it does have Anti Lock Brakes for veh from US. SE's and some LE's
