yellow_jacket »
https://forums.nicoclub.com/yellow-jacket-u4236.html
Wed Dec 03, 2003 2:33 pm
The SOHC motors have problems with the chain eating through the front cover. If your chain has been making noise for a while there is a good chance that is where your coolant leak is coming from(hole in the front cover) You would actually have to pull the front cover to check this. If there is no hole in the front cover, then check the head. Or you can check the compression and a blown headgasket will show up there.
By running coolant in the oil very bad things happen. Mainly the bearings are no longer protected and the motors life is greatly shortened. Not a very good thing to do if you want your car to last any length of time.
