Is there someone here who removed a heater core from a (salvaged) 97-99 in Albuquerque, NM?
98_Q45
I was at the pick n pull last month while visiting Albuquerque New Mexico. There was about 3 q45s in the lot (I must have went back and forth about 5 or 6 times getting all the parts I could think of I needed).
I noticed one had a heater core removed, and it was removed without removing the dashboard. I seen the evap box removed, but looks like it got a little damaged in the process. But atleast now I know where it is exactly, just behind and to the left of the evap box
If anyone out there knows, were you able to re-install the core without removing the dashboard and without breaking the evap box? I ask because my OE core is coming in, and considering I already took the dash out (only to put it back together), I am curious to know if I can get around it.
98_Q45
Never mind...figured it out. Mods can delete if want to
kt2112
Car: 1997 nissan altima high compression 11.3.1 ka24de
91 240sx hatch ka24det in the works
1997 q45
was there a coolant valve on the heater core/ or lines ?
