Is there anyway to make the heater produce higher heat?
naladude911
Car: 2001 Infiniti QX4
Winter has come to NY now, and with my heat cranked all the way up and my heated seats on, and the wearing of a jacket, I still feel cold. Is there anyway to modify the heater to produce more heat?
sicwitit
Car: part fabricator
maybe you need to increase your Iron intake. start taking multi-vitamins, that should cure your symptoms of anemia right up.
if your still having problems, you might have a heater core problem that could only be solved by testing it, and possibly replacing it. when is the last time you have done a coolent flush?
Pwnin O'Brien
Your air mixture door may also be malfunctioning or blocked. Slickroger posted a couple of pictures of how to diagnose the air mixture door in the 'NO HEAT' thread. I would suggest starting there, it only takes a few minutes to check.
Pwnin O'Brien
Also, try using recirculate.
fueler
Car: 2 Nissan's
2 BMW's
are u letting it warm up all the way? lukewarm air could be a bad thing. like if for some reason your thermostat was bad and the engine is not getting up to temp. my QX4 heater gets way too hot i cant even use it on full heat cause your face will start to melt.
Empty V
1982 Chevy Corvette C3 Shark
naladude911 wrote:Winter has come to NY now, and with my heat cranked all the way up and my heated seats on, and the wearing of a jacket, I still feel cold. Is there anyway to modify the heater to produce more heat?
Swap out your turtleneck with a sweater-vest. You'll be set!
Billy
sicwitit
Its a good thing I'm wearing boots.....
fitzx4
Billy
More CARBON FIBER VINYLS!!!
My heat is unbearable once the engine heats up enough obviously. You probably just think you shouldnt have to wait?
fueler
Car: 2 Nissan's
2 BMW's
