Dori Dori »
https://forums.nicoclub.com/dori-dori-u2872.html
Thu Feb 05, 2004 8:32 am
What do you mean by 'get rid of'? Do you want to 'get rid of it' or do you want to make it stop working?
The only way you're going to get rid of it would be to get a non-hicas subframe and swap the two. You would also need a non-hicas p/s pump. Since you have an RB though, I guess you don't even have your lines hooked up...with no line pressure, do your rear wheels toe in/out freely? Curious... Anyway, you'd also need to bore out the knuckle where the new toe arm would bolt up or get a non-hicas knuckle too.
If you want to make it stop moving around back there, you can place a 3mm washer on each side to lock it. I forget what nissan calls the two 'nuts' it would go between, but it's on the inner tie rod. That's all the arms move, 3mm left or right. With the two washers, it would be locked. You can also pull the fuse, but that will just make it stop working, not stop moving completely.
