numskul wrote:I should have offered a suggestion....Have you tried keeping a window or two down overnight? This should balance the temp/humidity on the inside and outside of the windshield and prevent the fog. I don't know what might get in your car if you do that, so it might not be feasible. I'd probably end up with a cat or racoon in my G...I'd rather have a fogged up windshield. Also, if there is any fog on your hood, roof or trunk lid, it may be the dew point in the garage was reached and dew is settling on everything. Less likely, but possible. If this is the case, keeping the garage door cracked a bit might help.
Well it never happens when the car is off or in the garage, it always happens when it rains and when i'm driving.
Focusedintntions wrote:our a/c's blow colder than 70......try raising the temp and don't put the defroster on high...keep it on very low....but condesation will form on the outside no matter what if it's humid and there's a high dew point.
Tried that and it still doesn't work
Is there anyone else that to deal with this problem?
