is there any way to tell if a relay is bad
SlidinSideWayzSR
Car: 1990 240sx SR. // 1991 240 SR.
i trying to fine out y my car wont start and i not have good luck battery good but im not getting power when i turn the key my fule pump dont even come on but i can turn my lights ona dnstuff like that so i was thinkin ign switch or a relay cuz all the fuse are good its on a s13
samxini
Car: '95 240sx w/Kouki conversion
I really have no idea what you said, please retype and use spell check because that was damn near impossible to read.
Merry Christmas!
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
put 12v across the coil, you can use a 9v battery also to test and ohm out the contacts and see if they open or close depending on the type
Roger_cha
Car: 91 nissan 240sx
well first of all what did you do before when the car was running... need more info on what did you do. try unplug the fuel pump harness in the back of the trunk and test it if there are any power, if not try just replacing a known good relay if that dont work then it might be your fuel pump or your ecu...
SlidinSideWayzSR
Ok let me some this up for you guys that dont under stand sorry about that.
i did nothing differnt other the put it on the battery charger all night long..
This is what i found out i bypassed the igntion switch by pretty much hotwirein it and its cranks over starts then stalls would that be cause by the switch or a relay
SlidinSideWayzSR
Update i jumped the accesery and the yellow and blk wire from the battery and it started and stayed runnin so i figured it was the igntion switch swaped it out and still nothing what else could it be
also where does the igntion switch get it power from what relay or fuse cuz i checked the fues and relays and theyy where all good
SlidinSideWayzSR
bump help
vancouverbc
Car: 1991 240sx
make sure the clutch interlock switch is ok. jumper it. or look at the green fusible links. its not obvious when they blow. test for continuity
mests13
Car: sr20det s13, 98 civic
seems like it might be the blue relay in between your battery and fender.
a few months ago i was having the same problems you where having and that ended up being the problem. there is a way to jump the relay, but i don't remember which prongs i crossed. i since got a good one from a friend and its started up just fine ever since.
