is there any way to fit 4lug rims on my maxima?
D_roc
Car: 2001 Maxima 20th aniv edition
b/c i cant find any cheap good looking 5lug rims i'm in a tight budget but there are plenty of 4lugs there so is there any way i can fit 4lug on it?thanksD
snwbrdr435
Car: 85 VW Westfalia, CBR F4i, SV650s, 1988 Honda Hawk(race)
im pretty sure you could find some cheap 5 lugs same price as four lugs. I am pretty sure you would have to do a 4 lug swap to fir the four lug wheels. I havent heard of anyone going from 5 lug to 4 lug. Usually it is the other way around.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Wow, I've never heard of anyone wanting to switch from 5 to 4 to make wheels EASIER to find.
I don't know if it'd be possible or not. You might want to look into B15 SER stuff...it MIGHT work.
I wouldn't recommend it, though. 4 lug is weaker. The Max is not a Civic.
Mike G
Car: 2001 Infiniti I30
D_roc wrote:..... there are plenty of 4lugs ....
There is a reason, nobody wants/needs them.... I'm sure for the right price, you can find an upper service tire or machine shop that can re-drill them for you. Of course you will want some that hide the bolts with the center caps. There may be some adapters available on Ebay, just becasue you can find everything there. Then you also need to consider the cost/benefit ratio of your undertaking compared to buying the correct wheels. --Mike
D_roc
is it ok to drill them will they still work good? and any idea how much it will cost to drill on 4 rims. b/c my tires are worn out now and the stock wheels are trashed curb rash on all 4 of them so i need a set bad
sweet3rdgen
Car: 1990 maxima se
You can't be serious? Besides the fact that 4 lug hubs are weaker than 5 lug, how could this be a way to save money?
Simply put there is no "free" way to do this. You cannot simply drill new holes in your hubs. They will become too weak and be very unsafe.
To do it and still be safe you will have to do a swap of the hubs to a 4 lug hub...and I don't believe there is a 4 lug hub that is a simple bolt on. And those hubs will cost you some money, probably as much as the difference for the rims you are looking at.
And since there is no easy swapping hub, you will have to have some custom machining done to make the hubs. That machining will cost much more than any rims you will want.
and let's not forget then that buying parts will not be an easy over the counter deal after doing the swap...more money. Just save up some money and buy the right stuff
