rsg123 wrote:
I think driving habits and tire pressure are the easiest and most effective ways to improve mpg in your M.
You may want to check your state's laws on this one, I have read in an article (on Yahoo! or MSN) that it is illegal to put your vehicle in neutral while driving down the road in some states. I agree it can make a huge difference in an M45, I don't understand why the transmission drags so much, but it is ridiculous.StevenRogers wrote:popping the car in nuetral is a good idea too. on my way home from work, i can get about 10 miles in on neutral. i work at 3000 ft above sea level and live at sea level.
-1 for youThe00Dustin wrote:You may want to check your state's laws on this one, I have read in an article (on Yahoo! or MSN) that it is illegal to put your vehicle in neutral while driving down the road in some states. I agree it can make a huge difference in an M45, I don't understand why the transmission drags so much, but it is ridiculous.
Q45tech - stop acting like you are better than everyone else just because you can do math - it's tiring and nothing you said helped anyone. Oh, and you said those calcs would give a "precise" fuel use at steady speed? Uhhhh...I think you forgot some things there because I'm not sure you'd even get in the ballpark with those calcs.Q45tech wrote:An educated engineer would always calculate the top gear ratio times diff gearing and correct for tire size to arrive at an RPM at say 60 mph then use engine displacement to arrive at a precise fuel use per mile at steady speed.
After all the ecu and O2 maintain a very very very precise use of fuel vs air to create a 14.7 to 1 AF ratio.
My 20 year old Q45 has a 3.538 x 0.694 or 2.455372 final top gearing with a tire rolling correction of 4.8% so 2.343 effective drive ratio.
1996 rpms at 60 mph.
Why magazine test usually show rpms at 60 mph so engineers can see what they are buying............easily without doing calculations.
Buying a car then complaining about it PROVES the buyer did an incompetent job of prebuy analysis. AND DESERVES WHAT THEY GET.
Yup - If you ever watch your Tachometer when doing this you'll see something else going on in manual mode(at least for the M45's). In manual mode in 5th gear the torque converter will lock at 65mph giving you a direct drive at any speed higher than that no matter the throttle position. It won't unlock until below 60mph.dvan wrote:One thing you can do to save some gas that I didnt notice anyone mention is to manual shift to 5th gear when you're cruising at highway speeds. You can use 5th by itself on the highway from 40mph or so and it should suffice for most passing/speeding up scenarios.
What happens most of the time in 'D' mode is when you want to pass someone doing 65mph, it usually downshifts to get up to speed. 5th gear by itself still pulls good at those speeds. I got about 24.5mpg doing some high way driving around 70-80mph.
What did you do? Copy and paste a Wikipeda article? Would you have preferred if he responded with "-1 for you" like you did to the other person who replied to this topic and was again trying to help out. Each person has their own way to respond to a topic, so stop bashing Q45 because he methods are different than yours. His post might not have helped you, but down the road someone might need that information. With 323k miles on his car, I can trust that he knows what he is talking about.ken in az wrote:
Lot more to consider to determine fuel usage than just revs per mile. Try throwing in fuel temperature, more specific measurement would be density or the specific gravity of the fuel. Need to also acount for rolling resistance from the tire, more specifically is tire size and compound. Need to know aerodynamic characteristics of the car/truck, more specific is the CD or coeficient of drag of the vehicle at said speed. Atmospheric conditions will also play a role in fuel economy as well. Barometric pressure, temperature, humidity will all play a role in how much oxygen will be present in the air the vehicle consumes. What a lot of people sometimes don't consider is how much of a factor Tempurature plays in the way an engine runs. Temperature directly reflects the speed of sound. Why is that important? Because the opening and closing of the valves of the engine create a sonic pulse that can aid in the cars ability to create peak torque at a given rpm. Change this and peak torque is not where you caculated and now that requires additional throttle to maintain the same speed. Also consider ignition timing, to advanced and it will cause a degridation of performance, to retarded and it will alsy degrade performance. Both of which affect toque output which can directly affect fuel economy.
Although slight changes in each of these factors on their own are a minimal distraction to fuel consumption, but start adding things up and together they can start to affect the rate of fuel consumption for said vehicle.
Don't beat the guy up for asking, it's a legitimate question. I'm sure he knows what he bought and like others have said, he owns several vehicles. He was simply asking any way to improve fuel economy. Your elitest attitude will be what drives people away from this site.
Uhh...nope that was all just out of my head actually.bredtime wrote:
What did you do? Copy and paste a wakopedia article? Would you have preferred if he responded with "-1 for you" like you did to the other person who replied to this topic and was again trying to help out. Each person has their own way to respond to a topic, so stop bashing Q45 because he methods are different than yours. His post might not have helped you, but down the road someone might need that information. With 323k miles on his car, I can trust that he knows what he is talking about.
P.S. In case you have forgotten you don't own this forum.....he does.
I never said that I didn't believe you, nor did I say that I believe Q45 over you. The fact remains that you could have replied to his post by just stating that his did not finish his equations - would have been much more productive. But, like I said, everyone replies in their own way and if that is how you like to reply, thats cool.ken in az wrote:
and the -1 for you was supposed to be a joke - just like that law that you mentioned. Really?? a cop is going to give you a ticket for coasting in neutral??
In case you didn't notice I was actually mentioning that his calculation was incomplete and there is much more involved in calculating fuel consumption other than basing it on "revs per mile @ 60mph" If you expect a 10% increas in fuel economy by switching your axle ratio then I've got some land in florida I can sell you for cheap - lol
If you believe what he's saying and don't believe me that's fine, but the way he goes about his posts are quite arrogant and elitest which is demeaning and probably doesn't make the OP feel too good about themselves. Really - did he get what he deserved??? Huh??? Did he??
Oh, and do you own NICO Q45tech? I don't see your name on this list...
http://www.nicoclub.com/staff/greg.shtml
I'm sorry, but why are you on this forum?saeedakobiakov wrote:stock to stock lexus is faster , period. there is not need for making any kind of jokes against more advanced lexus.toyota just more advanced then nissan.
Hey....this is funny :saeedakobiakov wrote:if i had money i would buy ISF in the hard beat.i just dont like people making fun of lexus, that is all.peace.,caug
Then, wait for M56 next year....saeedakobiakov wrote:gs 460, i said
so......are you sleeping with Q45tech now? do you guys grab beers together on sat nights now? Ken just happened to beat me to the punch line cause i was getting ready to unload on Q45tech myself cause the info he provides is simply USELESSbredtime wrote:
Modified by bredtime at 5:57 PM 11/5/2009
OMG.....another Jacka$$......let school begin...class is in sessionsaeedakobiakov wrote:http://www.roadandtrack.com/ar...=4459h ... ...testsIS 350 will blow doors of M45. i would not race them if i were you.so is gs 460 had better times throu 1/4.toyota makes fast cars.my friends ISF was 12.5 @117, that's faster then new camaro ss at [email protected] faster then c63 amg.all i am saying there is no need to make fun of toyota/lexus.they are faster.i think supra always smoked Z.but try for yourself to beat the hairdresser with IS350, let us know the results.
you know that's actually a tricky question and i'd be lying if i said i would know the outcome.Kosmos wrote:Here is a tricky question. If say we would take out of the M and IS all the insides (sets, carpet, electronics...) and race them again, who will win? To my understanding the weight of the M would be reduced more then the IS and just enough to get that head to head race )))
The IS350 would win hands down. It already has a lower starting curb weight and is under-rated in the power dept to the tune of 320bhp stock. I believe the M45 is spot on in the power dept but it has a little mushier transmission.Kosmos wrote:Here is a tricky question. If say we would take out of the M and IS all the insides (sets, carpet, electronics...) and race them again, who will win? To my understanding the weight of the M would be reduced more then the IS and just enough to get that head to head race )))
And by the way to the Lexus lover... IS-F is a performance car that comes in last within it's class. I don't suggest you dreaming about it. Try the M3 now that is a legendary and recommended with time performance vehicle. Truly to say I see Lexus as a girly brand now days too many stylish lines. The previous IS though was a masterpiece of design! Do you remember the speedometer looking like a fancy watch?
Why are you comparing apples and oranges? The IS is a small entry-level "luxury" sedan. The M is a heavier and much larger luxury sedan. I second the question: what are you doing in this forum?saeedakobiakov wrote:I bet m56 will be slower then my frieds IS-F [email protected] number is real.do the serch and see who can beat in its class. please dont you gt-r. it is almost race car.we are talking 4 door onces.m3 slower, amg is slower.do the serch again.
....and your point being???? it probably will be slower capt. dufus! you're comparing two cars from two different categories you're comparing full size luxury against entry level sport luxury. what's the point of having a luxury car if i can't even get my "3rd leg" in the door??saeedakobiakov wrote:I bet m56 will be slower then my frieds IS-F [email protected] number is real.
done!saeedakobiakov wrote: do the serch and see who can beat in its class.
ummm....that's stated where? and if that's the case is the corvette a race car too now?saeedakobiakov wrote: please dont you gt-r. it is almost race car.
please see my reply in post #2 ....i think i've done enough research for you.saeedakobiakov wrote: we are talking 4 door onces.m3 slower, amg is slower.do the serch again.
