Is there any difference I should know about between a Manual verses the autom,
Buddahlilbrother240
Car: 1995 240 sx se
I've been searching for the past couple of days for a new radiator. It looks like everyone is pretty happy with the KOYO aluminum unit. My question is does the 95 ka motor need a specific radiator (manual or automatic) for the transmission that is in the car. I only ran across One site that sells one or the other. My concern is, I have automatic now, but my project could become a manual when I add all the hp later. All help would be greatly appreciated!
Modified by Buddahlilbrother240 at 12:28 PM 1/29/2006
InsanityInc
Yes, the automatic transmission has a transmission fluid cooler if I recall. However, I'm pretty sure you can just block it off going from auto->manual.
Tulsa_S-13
Car: 1991 SR 240sx
Yes the automatic has a cooler in the radiator. If you convert over to manual you just block the lines on the radiator. Since you have an automatic now you need to find a radiator for the automatic.
Buddahlilbrother240
Car: 1995 240 sx se
Thanks for the information. Does anyone remember seeing a KOYO radiator for a 95 ka automatic? If so please include the web link.
InsanityInc
Well, as an addenum to this thread:
Don't buy a large aluminum radiator (koyo) if you're not racing. Better cooling isn't just for kicks. If your engine doesn't get hot enough, it will not run as well. On a normal street application, the koyo is likely to make your car lose power, by making your radiator more effective at dissipating heat (the source of your engine's power) from the engine.
So, basically unless you are overheating under race conditions: don't get a koyo.
Modified by InsanityInc at 6:41 PM 1/29/2006
^ Right on.
http://www.radiatorbarn.com - Get the stock replacement.
DjPantsSpecR
Car: 93 Nissan MS13
92 Nissan RMS13
also, if i'm not mistaken the stock automatic S14 radiators are already the largest ones you can get in a 240.
its bigger than the auto and manual S13, and i'm reletively certain the manual s14 radiator is smaller than the auto.
s14 2510's
Car: 96 s14 rb26 2510's fully built, 91 s13 sil truck rb20 in works
Get one with the steel tanks on it or they will crack again. (DJ knows that) I picked up one for my s14 before i did my rb26 swap. I ended up using it for 10 minutes than sold it DjPantsSpecR. I got it from a junk yard for $84 new but i worked it off sorting scrap. I now have a Koyo in my s14 but it needs that because it will hopefully be laying down like 600whp this summer. I know people with sr20 swaps laying down 300+ that still swear by the stock radiators. They all have upgrade electric fans that are keeping well cooled and they drift with there 240's.
guyaverage
Car: Nissan 240SX Convertible
Tulsa_S-13 wrote:Yes the automatic has a cooler in the radiator. If you convert over to manual you just block the lines on the radiator.
Actually the lines dont need to be blocked if he switches to a manual. The automatic cooler is just a coiled metal line that sits in the bottom of the radiator, and is sealed from the regular coolant flow.
You could use a radiator for a manual car but you will need to use an external cooler, which usually work much better anyway. I have done this on Mazdas, Nissans, Toyotas, Hondas.......have never had a problem.
Modified by guyaverage at 12:12 AM 2/2/2006
emperor_lunchbox
Car: 91 240sx, 96 eclipse spyder, and 96 camaro z28 (For Sale)
coudn't you use the cooler to cool the oil or something even if you are manual?
