is there an rb25 FSM / guide with info for piston replacement
ANVIL
Car: RB25DET S13.5
for some reason i always thought this info was in the fsm i have but just tried to look for it and its not. i want to prep myself with what exactly needs to be done when i reassembly my block. no i am not doing it alone but i just want to be prepared and have all the specs/tolerances ect available as well.
wanting pretty much all the info for the crank/rods/pistons to be replaced. thanks
ANVIL
Car: RB25DET S13.5
Does anyone know if rb26dett procedures and specs would be the same for rb25det? I found one but only shows rb26dett
ANVIL
Car: RB25DET S13.5
Bump! Still looking for rb25 specific or if someone can confirm rb26 is the same for assembly
RRRRB
Car: 98 RB powered S14
Is your engine going to be using stock rods and pistons?
ANVIL
Car: RB25DET S13.5
No.
Manley rods with cp pistons. But i dont think i need it anymore. Decided to just have a machine shop do the assembly
RRRRB
factory specs pretty much go out the window with forged pistons
